Excellent second board technology, derived from the black technology of Mitsubishi in Japan
TP
700-6500T
Originator of True Two-Platen Technology
Chen Hsong: First in China to successfully develop large-tonnage true two-platen injection molding machines
Four Core Patented Technologies
High-Speed Auto Mold Adjustment
Tie Bar & Hydraulic Connection System
Tie Bar Thread Engagement Structure
Circular Platen Design
Chen Hsong: 70 Years of Industry Leadership
True Two-Platen Technology: 30 Years of Innovation
Patented High-Speed Auto Mold Adjustment
(Patent No. ZL200720151407.X)
· Completes max-stroke clamping cycle in 8 seconds
· Significantly shortens production cycles
· Enhances precision & efficiency
Patented Tie Bar & Hydraulic Connection Design
(Patent No. ZL200720151405.0)
· Achieves uniform mold force distribution
· Ensures smoother machine operation
· Improves mold open/close accuracy
· Extends machine & mold service life
Patented Tie Bar Thread Engagement Structure
(Patent No. ZL200720151406.5)
· Enables high-speed, low-noise operation
· Delivers ultra-high precision and exceptional stability
Patented Circular Platen System
(Patent No. ZL201921456799.X)
Uniform stress transmission → higher yield rate
Compact Footprint, Extended Stroke
• 50% larger mold opening stroke & capacity than standard three-platen machines
• Specifically engineered for:
✓ Large-scale applications:
- Home appliances | Automotive components
- Building elements | Pallets & water tanks
✓ Deep-cavity molded parts
World-Class Injection System Design
· Optimized 22:1 L/D screw ratio → zero plasticizing defects
· Rigid mounting bracket → superior motion accuracy
· Triple-bearing support → extended service life
Intelligent Control System
· Gen3 Servo Drive → +60% mold position repeatability
· Advanced SMT technology → enhanced component reliability
· Industry 4.0 ready → seamless smart factory integration
True Two-Platen Robust Performance
SM-TP (Superior Moldability for Thick Products)
• Large appliances | • Automotive components
• Building elements | • Pallets & water tanks
• Oversized & deep-cavity molded parts
Contact Us
Your Name
Country/Region
Focus Areas
