Dedicated Machine for Thin-Wall Packaging Industry
SUPER PACK
430T
Reinforced Thick-Platen Structure
• Mold repeat positioning accuracy ≤1.0mm
• Platen parallelism ≤0.2mm/m
Oversized Reinforced Tie Bars
Deflection rate ≤4% under max clamping force
Reinforced Frame Rigidity
Production stability
High-Speed Dedicated Controller
• Bus-based real-time control system
• Proven hydraulic control circuits
Enhanced Clamping Structure
• High-Performance Alloy Tie Bars
Ensures mold opening/closing stability
• Reinforced Thick-Platen Design
higher rigidity than benchmark platens
Enhanced Injection System
• Nano Infrared Heating
faster heating rate
improved thermal retention
• High-Plasticizing Screw
51% higher material processing capacity
• Precision Linear Guideways
Enables jerk-free injection motio
Enhanced Hydraulic System
• Flanged Piping Network
Zero-welding design → eliminates oil leakage risks
• High-Response Servo Pump
29% power density increase
• NAS 6 Class Bypass Filters
Oil cleanliness
Extends hydraulic component life
Enhanced Control System
• HD TFT Touch Controller
Intuitive 3-step operation
• Hydraulic Plasticizing Synchronization
Cuts cycle time
• Closed-Loop Hydraulic Control
Pressure stability
Compliant with PLd Safety
Contact Us
Your Name
Country/Region
Focus Areas
