Brilliance
MK6.6B
88-668T
High precision
High precision
Equipped with linear guide rails and nitrided mixing screw, the machine operates with greater precision.
Superior stability
Superior stability
High-strength machine base, improved structural stability, reduced deformation.
High-speed
High-speed
Compared to traditional hydraulic machines, the dry cycle time is reduced by 13% and the speed is increased by 15%.
Professional screw designs
Available for an amazingly wide range of applications demands and resins.
Linear guide rails for injection
High stable, high precision, high repeatability
Barrel inlet zone heat preservation
Stronger adaptability. Making it easier for the plastic to fill the mould.
High-strength platens
Low platen deformation ensures high part quality and superior mould protection
Next Generation Servo
Drive system - Low energy consumption, saving up to 50% energy compared to traditional variable pumps
Brain of the Machine – Superiority Guaranteed
High-clarity 10”LCD panel with wide colour range, high-accuracy PID barrel temperature control
Contact Us
Your Name
Country/Region
Focus Areas
