Local Expertise Within India
MK6.6 SI
88-658T
High precision
High precision
Equipped with linear guide rails and nitrided mixing screw, the machine operates with greater precision.
Superior stability
Superior stability
High-strength machine base, improved structural stability, reduced deformation.
High-speed
High-speed
Compared to traditional hydraulic machines, the dry cycle time is reduced by 13% and the speed is increased by 15%.
Professional screw designs
Available for an amazingly wide range of applications demands and resins.
Linear guide rails for injection
High stable, high precision, high repeatability
Barrel inlet zone heat preservation
Stronger adaptability. Making it easier for the plastic to fill the mould.
T-slot with Mounting Holes
Significantly reduces mold changing time
Next Generation Servo
Drive system - Low energy consumption, saving up to 50% energy compared to traditional variable pumps
Top-Of-The-Line Precision Control
· 12"large-sized touch screen LCD panel
· Wicked-fast CPU for lightning responses
· Ultimate user-friendly HMI
· intelligent controls and easy smart tuning
· Hourly production display
· Comprehensive features set
Contact Us
Your Name
Country/Region
Focus Areas
