Productivity is never an after-thought. You need the MK6 plus’ power and specifications to stay ahead. And they keep you ahead.
Stability Plus
Only the best machining equipment (e.g. Japanese FMS’s and CNC’s) is good enough to produce core components for the MK6 plus, which all but guarantees reliability and stability for long years of operation.
Yield Plus
The task may be demanding, delivery unforgiving, but the MK6 plus has you covered. Its ample power and generous specifications make any moulding task simple.
High precision linear guide rails
Low-friction linear guide rails ensure silky-smooth, higher positional accuracy for higher yields
Professional screw designs
Significantly improving injection and plasticising efficiency
Ceramic heater
Improved efficiency of barrel heating and high-pressure resistance.
High standard core pulls
Meeting customers'requirements,without the need for separate ordering and reducing delivery lead time
4th Generation Servo-drive system
Combines a fast-response gear pump with a high-precision servomotor, dynamic response and low noise level
Luxury controller
12" Next-gen intelligent computer controller, 800x600 resolution, 250us cycle scan time. Advanced high-speed CPU enables lightning-fast closed-loop calculations for faster responses and high precision
